Thread: Problems with lathe
22-08-2022 #12
Hi, all I was asking the stepper motor to do was move a set distance, so I could measure it and set the steps. Unlike mach3 mill, mach3 turn doesn’t have an automatic calibration system. The only way to set the steps is by asking the motor to move, measure and adjust until you get the right number of steps. I did not know that I had to also input a speed. I just had the idea that the motor would move at the same speed it did when jogging. Is this not correct? I am trying to follow a video on utube by a chap who went through this process. But like many things so much is left out. And the mach3 manual is very grey in this area.
Harrison Alpha 330 lathe Fanuc 21it SRAM back up problems
By Sucram in forum General DiscussionReplies: 14Last Post: 24-02-2021, 03:44 PM -
Harrison Alpha 330 lathe Fanuc 21it Work offset and Work shift problems
By Sucram in forum General DiscussionReplies: 0Last Post: 15-12-2019, 09:44 PM -
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
Help please with warco 220 lathe motor problems
By wiggy in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 07-09-2010, 10:14 PM
