12-09-2022 #21
Yes, they refer to the 4th axis or motor output. If you are slaving motors with the 4th axis then usually you would turn off the LIMIT++/-- in ports and pins but leave the HOME input so can home. In this case, the M4 will light up when homing and then go off after the axis as backed off the switch, which I think is probably what's happening in your case but you have the LIMIT turned on and using the same pin number so the M4++ lights up as well.
In which case this would be correct when homing if the Home SW. safety button is not set in the General config screen while homing. If the Home SW.safety was ticked you would get a Limit tripped error.
Edit: Ignore this I can see it's been answered. It's been several weeks since I've been on here and this showed as a current post on my system.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
01-02-2023 #22
That looks off topic.
Sumtor Control Board - homing/limit switches
By Roy-J in forum Motor Drivers & ControllersReplies: 16Last Post: 26-05-2021, 08:29 PM -
High Precision Homing Switch
By Chaz in forum General ElectronicsReplies: 19Last Post: 17-04-2018, 05:34 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
By Shinobiwan in forum Items For SaleReplies: 6Last Post: 02-02-2013, 10:54 AM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
