Thread: help with a 4' by 9' cnc build
28-12-2009 #6
If you hunt through his site you will find information on BlackToe, his 8' x 4' design using chain drive.
If you want to go with leadscrews you will need a ballscrew of 25mm diameter with fixed bearings at each end holding the screw in tension. With a 5mm pitch this will give you 1200mm/min (50ipm) cutting speed and 3200mm/min (125ipm) rapids (limited by screw whip) using an 8Nm NEMA34 stepper with decent drivers (50 or 60volt drives).
For the short, 4', axis a 16mm x 5mm ballscrew simply supported and a 2Nm motor would suffice.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
