Thread: Wire Feeder
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 803. Received thanks 101 times, giving thanks to others 176 times.
    not to sure about this one, so never made a comment earlier. I cant see how its going to be better than manualy feeding the rod. In a MIG set the current is comming down the wire and flashes off to droplets of material. also i do believe the power supply is different(could be wrong here).
    Doddy its easy enough on my setup and i am no expert but first off every thing has to be spotlestly clean, once you have the Amps dialed in you get your pool and dip the rod into your Argon shield to heat the wire and then as you move nearer to the arc touch it on your work piece
    Ther are some goods videos on youtube .
    Regards
    Mike
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 9 Hours Ago Has been a member for 8-9 years. Has a total post count of 476. Received thanks 77 times, giving thanks to others 25 times.
    .....i do believe the power supply is different(could be wrong here).
    Yes, TIG and stick sources are generally constant current (CC), whereas MIG / MAG is constant voltage (CV). Your plan may work to some extent but I expect you may struggle to maintain a stable arc. MIG / MAG welders are pretty cheap, so you may be better just buying a pukka machine for that. A logical next step for your TIG equipment might be an AC source so that you can weld aluminium.
  1. Which wire goes where
    By terry1956 in forum General Electronics
    Last Post: 29-04-2020, 02:02 PM
  2. Wire EDM machine
    By Neale in forum Other Machines & Building
    Last Post: 05-11-2018, 09:31 AM
  3. Wire diagram
    By Raymond in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 11-06-2014, 06:24 PM
  4. CNC hot wire cutter
    By Nstocks in forum Machine Discussion
    Last Post: 22-05-2014, 07:54 PM
  5. Sameca bar feeder problems
    By Greggy in forum Machine Discussion
    Last Post: 10-01-2014, 01:25 PM
