    I may have repaired a similar encoder (at least I recognise the name of the turret) before now for another forum guest. Anyway, the first thing I'd look at is if there's a pull-up on the inputs to the PLC. Gimme a sec, let's see if I have some old photos...
ID:	31273Click image for larger version.
    If your encoder looks like one of these - essentially, unless there's a common-mode failure (e.g. supply line to the PCB) then each of the 6 signals is independent from the other - and it's highly improbable that the entire encoder has failed. I'd have to really dig around for any notes I may have but believe the encoder outputs are open-collector. If the PLC doesn't provide a pull-up, or cannot be configured to switch-in a pull-up then try with a 1k-10k resistor between DC+ and the output.
    For information - the failure mode experienced by this encoder - twice over two years - was the failure of the photo-diode on the encoder board. Last pass I replaced all diodes.
    I don't think my encoder looks like that. The encoder looks like this.
Name:	AG10 12 POS BARUFFALDI-p.jpg
    However, I'll consider what you've said. Thank you!
    Edit: If you're pertaining to opening the inside of the encoder, I might check it later.
    Quote Originally Posted by Jerico View Post
    Actually - that's very interesting - that looks very much like the common-or-garden quadrature encoder - can you post details of the label? (I've tried magnifying and angling the laptop, but can't see enough detail). But I might be heading down a rabbit-hole here. But a quick image of the label....
    Edit: Still think testing pull ups is a quick and easy test.
    The thing is the photo I used is just a generic photo of what mine looked like. Since the CNC and the tool turret with it are around 20+ years old, someone might have removed the label. Some things are for sure: (1) It is an 8-Position Absolute Encoder; (2) It looks like the photo I attached; (3) I think it is the original encoder from the Baruffaldi TOE-100 Turret (since the wire colors and how it is assembled to the turret fits the TOE-100 manual).
    I'll drop an update after testing pull-ups. Thanks for that.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 8-9 years. Has a total post count of 491. Received thanks 82 times, giving thanks to others 27 times.
    The position switch on the hydraulic turret on my Tree lathe looks like this visually but it's actually an "8 position rotary switch" by Sanyo. I'm pretty sure mine actually has 8 reed switches in it, as it beeps out in either direction with a DVM. The giveaway is that it has 9 wires.
  1. 110v 3 phase for baruffaldi turret
    By jonnydeen in forum Motor Drivers & Controllers
    Last Post: 06-09-2020, 11:48 PM
  2. Baruffaldi RH80 turret
    By Dangle_kt in forum Denford Lathes
    Last Post: 14-03-2018, 03:35 PM
  3. Chester 626 turret mill
    By Robin Hewitt in forum Machine Discussion
    Last Post: 29-08-2017, 04:40 PM
  4. Denford Starturn Turret
    By Leadhead in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 11-09-2013, 08:36 AM
  5. CNC Turret Mill range
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 28-11-2011, 07:23 PM
