    Hi all, just trying to set up a 4kw 380v VFD for controlling the speed of a spray booth extract fan, 3 phase 1440 rpm. out of the box using the rotary knob the max speed I am getting is about half what it was when direct on line, help would be appreciated. The manual is very difficult to take in.
    Quote Originally Posted by Pugwas View Post
    You need to supply more info for us to be able to help, such as the model # of VFD Huanyang makes many different models and any parameters you have changed or set up. Also, details on the Motor plate would help. ie Voltage, current, etc.
    Also, are you sure it's a 380V output VFD.? Most are 240 single-phase inputs with 240V 3-phase output. Not many provide 240v input with 380v output and I don't think Huanyang makes one but could be wrong on that.!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Hi Jazzcnc, The VFD is 3 phase in and 3 phase out (380v) 4kw and brand new. Motor is 4kw 420v 50hz 1420 rpm 8.5 Amps, I did a factory reset on the VFD which changed the parameters from 400 Hz to 50
    The motor speed can now be controlled but only via the up/down arrows, when I change the setting to be controlled via the rotary knob the motor will only ramp up to half speed. Using it with the arrows but would be better if I could use the knob
    We need that model number or a link to the manual @Pugwas if you still need help...
    https://www.ebay.co.uk/itm/383807374...mis&media=MORE
    This is what I purchased
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    What supply are you providing to the power-input to the VFD?
    That link suggests a 380VAC(400VAC, UK) 3-phase supply is required.
    Yes it’s a 3-phase supply, no neutral.
  1. Huanyang VFD problem
    By Ash88 in forum General Discussion
    Last Post: 23-02-2021, 10:20 PM
  2. Huanyang VFD dl Error
    By charlieuk in forum Spindles & Drive Motors
    Last Post: 12-05-2017, 07:59 PM
  3. Huanyang VFD repair
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 27-01-2017, 10:57 AM
  4. help connecting a pot to huanyang vfd 2.2
    By edgas10 in forum General Electronics
    Last Post: 14-08-2016, 06:45 PM
  5. huanyang vfd 2.2 error E.CO.A
    Last Post: 01-07-2012, 08:12 PM
