Thread: Huanyang setup help
29-09-2022 #3
Hi Jazzcnc, The VFD is 3 phase in and 3 phase out (380v) 4kw and brand new. Motor is 4kw 420v 50hz 1420 rpm 8.5 Amps, I did a factory reset on the VFD which changed the parameters from 400 Hz to 50
The motor speed can now be controlled but only via the up/down arrows, when I change the setting to be controlled via the rotary knob the motor will only ramp up to half speed. Using it with the arrows but would be better if I could use the knob
Huanyang VFD problem
By Ash88 in forum General DiscussionReplies: 1Last Post: 23-02-2021, 10:20 PM -
Huanyang VFD dl Error
By charlieuk in forum Spindles & Drive MotorsReplies: 7Last Post: 12-05-2017, 07:59 PM -
Huanyang VFD repair
By paulus.v in forum Spindles & Drive MotorsReplies: 1Last Post: 27-01-2017, 10:57 AM -
help connecting a pot to huanyang vfd 2.2
By edgas10 in forum General ElectronicsReplies: 15Last Post: 14-08-2016, 06:45 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM
