Thread: ATC Adapters (Mechatron)
20-08-2023 #1
Hi all
I know the likely response to this post (assuming there will be some), is that adapters aren't as good as the real thing. I agree!
But how bad or good are they?
I would also like to know how much work + added costs go into performing this conversion (although I suspect that's a thread for a different part of the forum?).
I currently run a:
1x Huanyang 400HZ ER20 80mm 2.2kw water cooled spindle
1x Huanyang HY series VFD spindle drive (although I don't expect an adapter to interfere with that since it runs off the initial spindle)
I assume there will need to be some software situation which tells the spindle to go to the tool change area etc...
I use UCCNC software. (it's a JazzCNC machine).
Any help; much appreciated.
Kind Regards
Anyone using Mechatron STC-80 ATC?
By Tenson in forum General DiscussionReplies: 7Last Post: 16-10-2020, 03:19 PM -
USB to serial adapters
By Robin Hewitt in forum General DiscussionReplies: 0Last Post: 26-11-2017, 11:08 PM -
Mechatron HFS range of Spindles
By cambesol in forum Spindles & Drive MotorsReplies: 4Last Post: 24-11-2013, 05:55 PM -
RFQ: Aluminium wheel Adapters needed
By 1username in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-02-2010, 10:50 PM
