No problem your welcome and welcome to the forum!
Yea, my guess is the first job weakened the cutter, the second job killed it...you cant rely on those cutters, not if you want to do it properly with cnc :)
Ok scrap that idea about half the cutter diameter, the general consensus is you should aim/start with a DOC that is equal to the cutter diameter, this is CNC machining so we should be looking for the most efficient cycle times, that result in the best possible surface finish etc. So, from the starting point of a DOC equal to the cutter diameter, we can go north or south of this depth depending on the situation (efficiency, surface finish etc).
The problem I've noticed with the various "speeds and feeds charts" dotted about is they don't seem to emphasise enough on a few things in my opinion.
I mean the Rennie page suggests:
Ok, so what dose that actually mean?The recommended chip load & feed rate data provided below is a recommended starting point and may not accommodate all circumstances.
Well firstly, it should be assumed that any of the charts provided by tool manufactures ONLY really cover the cutters they provide, when you start going to "branded" tooling, these charts are helpful BUT they are ONLY jump off points to get you in the right ballpark.
When they produced these charts, they did so on a different machine and under different circumstances to our own, so with that in mind everything should be treated as relative, its ok though because some of the fun is exploring and finding the sweet spot for our own circumstances.
The Rennie page didn't do to bad a job when they said:
So really all I would advise anyone to do, is use these charts to get an approximation of the chip size for the material you want to machine, the rest is going to change and be different for everyone.As a rough rule of thumb we usually advise the depth of cut as 1 x cutting diameter. However, in some circumstances a smaller or larger depth of cut may be optimal.
Always start out at the lower feed rate and work your way up from there until optimal cutting conditions and speed is acquired.
Rennie also state
I would say this is ok to get started with and quite a few seem to suggest 18K for the RPM, maybe its a good general spindle speed with plenty of torque for most feeds in lots of different materials, its not for everything though.We would recommend running at 18,000 RPM for most single, 2 flute and 3 flutes up OR down cut router bits
What they didnt say:
Spindle speed (RPM) is BAD for the longevity of cutters, End Mills, Router Bits etc.
When metal gets hot it also turns soft and this is no different for our cutters, to much spindle speed can generate heat in the tool and this will just make it blunt sooner. If you slow down the spindle speed it will give better tool life, when you find the right sweet spot and the perfect chips are coming off the material, make a note of the feeds and speeds, do the maths so you've got the magic chip size available for the circumstances/material, then you can start tweaking the spindle speed down adjusting the feed rate as you go in order to maintain the correct chip size you know works best for you. Keep in mind then that lowering the spindle rpm is better than reducing the feed rate.
Keep an eye out for the feed rate becoming to slow, we don't want the cutter to rub, get hot and then soft (tool life) we're looking for chips not dust!
A chip size of 0.483, a feed rate of 17,388mm/min with a 6mm DOC.
See the problem is, when you start going up in cutter diameter, the numbers want you start running your feed rates at some CRAZY speeds in order to maintain that magic chip size we love so much, when in reality, are those feed rates even viable. My comments are not so much aimed at the 17,388mm/min here but that feed rate should be observed, when you start getting up there in the feed rates, things like tool deflection start becoming a concern, what's the length of the tool below the holder, can we do those feeds with that depth of cut with a tool this size, is our machine even ridged enough, will accuracy be effected. Food for thought that's all.
You haven't said if you also adjusted the spindle speed, I'm going to assume you never and that's what allot of people do, they assume slower feed rate equals "safer" but its not always true, especially if they don't understand the feed rate/spindle RPM relationship to chip size/load. Lets do an example on the assumption of Oli not having changed the spindle speed and what those numbers then tell us about the chip size he was producing that may have caused the cutter fail.
To do this we will need to do the maths the other way:
Chip Load = Feed Rate (millimetres per minute) / (RPM x number of flutes)
Feed Rate: 4,000 mm/min
Spindle: 18,000 RPM
Tool Edges: 2
That tells us our chip load is: 0.111 = 4000 / 36000
So we could assume that when the cutter failed for Oli it was because rather than producing proper chips sized at 0.483 it was instead "rubbing" the material away and producing dust relatively speaking, this rubbing then caused the tool to get hot and combined with it just not being up to the job, to then fail.
Oli when you recovered the project using the 6mm solid carbide cutter, what feeds and speeds did you use, the chips in that second video look better, though it dose sound like its screaming a little bit still. The cheap bits are not a total waste of time, you just have to be a little more conservative with them, don't be nervous mate what's the worst that can happen, just "send it" and be confident in your work, we learn from the ways that don't work :-)
Hopefully I've given you enough info to answer your later questions on how to approach F&S etc, if not just ask away that's what the forum is for, for now keep the stepover small just while you find your feet so to speak, once you feel better about it all and get to know your machine and tooling more, then you can start looking to push their limits, I don't think there is an issue with your spindle, I think you would see problems in the bottom of the pocket (finish) if it was out of true etc, Andrew is correct on the using your ears and I'll add eyes (chip size) to help establish if things are running correctly, also another good easy to do tip is to check the cutter after a job to see how hot it is, warm to the touch is ok :)
Key tray looks great, brilliant feeling when you take something off the machine for the first time isn't it :)
Did you get a Jazzy (Dean) machine in the end or something else ?Last edited by Lee Roberts; 12-10-2022 at 10:04 PM. Reason: speeling
Thanks for all the info Lee. I've read it a few times trying to absorb it.
Good assumption for the 6mm endmill I used 4000mm/min feed rate 18000RPM and a 3mm DOC, stepover 40%You haven't said if you also adjusted the spindle speed, I'm going to assume you never and that's what allot of people do, they assume slower feed rate equals "safer" but its not always true, especially if they don't understand the feed rate/spindle RPM relationship to chip size/load.
Spindle: 18,000 RPM
Tool Edges: 2
So we could assume that when the cutter failed for Oli it was because rather than producing proper chips sized at 0.483 it was instead "rubbing" the material away and producing dust relatively speaking, this rubbing then caused the tool to get hot and combined with it just not being up to the job, to then fail.Oli when you recovered the project using the 6mm solid carbide cutter, what feeds and speeds did you use, the chips in that second video look better, though it dose sound like its screaming a little bit still. The cheap bits are not a total waste of time, you just have to be a little more conservative with them, don't be nervous mate what's the worst that can happen, just "send it" and be confident in your work, we learn from the ways that don't work :-)
With the bit screaming as you suggest which setting would you have adjusted? I'm guessing you would have adjusted the RPM down? I would have probably been tempted to reduce the feed rate. I probably need to practice different settings on a scrap piece of wood to get a better feel for it.
Lot's of info thanks, The cutter was warm after this project not too hot to touch which is a good sign.Hopefully I've given you enough info to answer your later questions on how to approach F&S etc, if not just ask away that's what the forum is for, for now keep the stepover small just while you find your feet so to speak, once you feel better about it all and get to know your machine and tooling more, then you can start looking to push their limits, I don't think there is an issue with your spindle, I think you would see problems in the bottom of the pocket (finish) if it was out of true etc, Andrew is correct on the using your ears and I'll add eyes (chip size) to help establish if things are running correctly, also another good easy to do tip is to check the cutter after a job to see how hot it is, warm to the touch is ok :)
Never get tired of it, it's great seeing a design go from the PC screen as you intended it to.Key tray looks great, brilliant feeling when you take something off the machine for the first time isn't it :)
Yes mate I did, It's a great machine that Dean and Jared made for me. Really pleased with it.Did you get a Jazzy (Dean) machine in the end or something else ?
21-10-2022 #3
Help with speeds/feeds please?
By examorph in forum Tool & Tooling TechnologyReplies: 5Last Post: 29-01-2017, 01:54 PM -
Speeds and feeds
By eurikain in forum Workshop & EquipmentReplies: 3Last Post: 26-03-2016, 06:00 PM -
Feeds and speeds software
By suesi34e in forum Swarf & Chip ManagementReplies: 4Last Post: 22-03-2016, 10:30 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
