Thread: Milling Machine Advice
Ok with the material now confirmed, maybe a better option would be to have the parts cut by laser in bulk when you can?
It all depends how deep down the cnc rabbit hole you want to go really, but for SS and/or CS while those materials can be cut, your going to need a decent (rigid) machine to do it properly/reliably. Its also going to come down to a cost vs time thing, have you got the time to learn about machining and cnc (great fun if you have), or do you just need an easier solution and its about the bikes for you?
Have you been drawn to a particular machine yet?Last edited by Lee Roberts; 22-10-2022 at 06:14 PM.
Milling Plastazote LD33 closed cell Foam - Any milling advice?
By Zeeflyboy in forum General DiscussionReplies: 17Last Post: 06-04-2022, 10:12 PM -
Milling aluminium advice needed
By zxrjohn14 in forum General DiscussionReplies: 8Last Post: 08-11-2017, 02:18 PM -
4Axis 0.8KW Router Engraving Machine Milling Drilling Engravor 3040 CNC Machine
By KeithElcomb in forum Chinese MachinesReplies: 0Last Post: 27-09-2017, 12:32 PM -
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM
