Thread: Smiler's Build
27-12-2009 #9
Hi Gary,
Thanks for that. I'll order some cable later in the week. The fuses I plan on using are car blade type, will they be ok do you think?
Also,
Lubricating the ballnuts, what should I use? I have some Lithium High Melting Point (costs a fortune) grease which I use on the tractor, would that be good enough or is there some specific grease I should use.Nothing is foolproof......to a sufficiently talented fool!
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
