Thread: Smiler's Build
    Hi Everyone,
    Well, the mechanical part of the router is almost there. The router is now mounted and I've done a few sneaky test cuts which were very successfull considering I don't have proper mills yet, only router cutters.
    I still need to buy and fit my energy chain to keep the pesky cables under control as you can see. The yellow and white colied wires are my touch probe for setting X,Y and Z and for centre finding. Works really well.
    I got lucky with my choice of router. I was going to use one of my Triton routers but they are such an odd shape so I thought about dismantling my Makita 3612 which is in the same HP league as the Tritons (3 1/4). It turns out that the plunge slides are exactly 20mm diameter, the same as the precision rail I bought from Zapp and so all I needed to do was to fit two 20mm mounting blocks to my Z axis plate, fit two offcut 20mm rails into them and drop the router on. Tighten up the plunge locking screw and the router is solid, the whole thing works a treat. One massive bonus is that I can remove the router in ten seconds, and have it back on its plunge base in another ten minutes.
    I'll post more photos as and when I get my Energy chain.
    Jeff
    Great looking machine and signs, I have two CNC4PC BOB's and both have been very easy to set up and operated flawlessly so far, as you know I am still in the early stages of getting my machine up and running so they have not been used in anger yet, also Arturo is very helpful and very quick to answer any questions.
    Andy
    Hey Smiler,
    I just put in my order for one of DIY Cnc's BOBs, and I'm a little concerned that you're going with a different make. Was it a user error, or did it give up the ghost on its own? :D. Should I be thinking about canceling my order, and going with someone else?
    I really like what you've done...
    Dave.
    Quote Originally Posted by lateAtNight View Post
    Hey Smiler,
    Dave.
    User error Dave. My main BOB is a DIYCNC Uniport and I'm very pleased with it indeed. Buffered outputs for 4 drivers and three relays onboard that don't need external power. The original one was an Optoport which I shorted out trying to wire in a relay in my hamfisted way. Roy repaired it FOC and I put it back in as Port2 so I could have some extra inputs to Mach. Well, I managed to do the same trick and shorted out the board AGAIN and I just can't face asking Roy to fix it again. It was my own stupid fault "tinkering" when I should have just said "right, that's the controller finished". What I was thinking of doing was just getting an opto-isolated BOB which can use pins 2-9 as inputs as that would be what I really wanted and DIYCNC don't do them or I would be buying one from Roy ASAP.
    If you've seen my other post this morning about the U-HID interface, well that would mean I don't actually need another BOB at all and that might be the way I go now.
    Don't think you will go wrong with DIYCNC, they are very well made boards.
    Regards, Jeff.
    Quote Originally Posted by Kip View Post
    I hear ya....It's grim up north :D
    Iii it is nothing but rain and more rain all week and all weekend !
    (Wigan)
