Thread: Smiler's Build
27-12-2009 #20
ah.... are RSJ's that flat then? I was wondering about getting something flat to work on... I have my eye on a granite worktop I have seen in a skip nearby (some people have more money then sense), but I have no idea if I could lift it out and get it home.
Table saw, planer???... wish I had the space for these, best I can do is a cheap Skil jigsaw and a B&Q circular saw... and a hand planer :D
You're welcome Jeff, I have used something similar in the past, two sections of 16mm dia tubing joined by a old door return spring. Cables ran inside some square section lidded 16mm trunking screwed to tubes with a spiral wrapped loop at the spring junction. Look forward to the pics
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
