Thread: Smiler's Build
27-12-2009 #13
User error Dave. My main BOB is a DIYCNC Uniport and I'm very pleased with it indeed. Buffered outputs for 4 drivers and three relays onboard that don't need external power. The original one was an Optoport which I shorted out trying to wire in a relay in my hamfisted way. Roy repaired it FOC and I put it back in as Port2 so I could have some extra inputs to Mach. Well, I managed to do the same trick and shorted out the board AGAIN and I just can't face asking Roy to fix it again. It was my own stupid fault "tinkering" when I should have just said "right, that's the controller finished". What I was thinking of doing was just getting an opto-isolated BOB which can use pins 2-9 as inputs as that would be what I really wanted and DIYCNC don't do them or I would be buying one from Roy ASAP.
If you've seen my other post this morning about the U-HID interface, well that would mean I don't actually need another BOB at all and that might be the way I go now.
Don't think you will go wrong with DIYCNC, they are very well made boards.
Regards, Jeff.Nothing is foolproof......to a sufficiently talented fool!
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
