I've never personally used V-carve so can't comment, but I'd normally design the parts with suitable radiuses or select the cutter to avoid radii matching.
I can't remember the last time I had to machine an internal sharp corner, so I can't even think how my usual choice of F360 handles it, but I'm sure there will be a setting somewhere.
R&P can work if designed well, and you're not expecting micron tolerances.Regarding the helical rack and pinion, what's the other option for larger machines? (Not necessarily mine), as I understand it ballscrews run into vibration and whipping issues at longer lengths?
Just curious for if I get a bigger machine in future.
I understand it's not a high end machine, but similarly it's not a wet noodle from AliExpress, it certainly seems like it should be capable of holding the tolerances I desire....operator error aside.
The next league up of machine is well into the tens of thousands, unjustifiable currently.
Other options are rotating ball nuts, supported ball screws, high pitch ball screws.
There's not really an ideal solution, but as with most things, it can be done if you select the correct components.
But I hate to tell you, you can probably buy your machine on Aliexpress, if not, Alibaba.
I looked at a 4x4 machine, and there are some compelling options, but they're all built to a price.
It's a shame Jazz isn't about, as he's the one who really knows about Routers (I'm more metal working, than wood bothering!)Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
unwanted edge in solidcam
By kell in forum SolidworksReplies: 0Last Post: 01-12-2016, 03:22 PM
