Thread: Desktop beast
27-10-2022 #4
Welcome to the forum!
Following along also, on first sight I did think "oh the webbing on that looks a bit thin for this", then I read the post and viewed the last image :) certainly looks well made...
Edit: Seen the website dont need an answer to this question.
The M12 is nice, is it the correct hole size for tapping or just close enough, Vallder is a new one to me so will be off to their website in a mo, do they design this profile for this specific application with regards to everything fitting nicely (rails, bearings etc) or ?
Are you making the plates yourself or do you have help with those?
Concrete
What type and mix are you using, standard Portland type isn't really up to the job you know, may be able to advise you here if you don't know why?
Ooo El Beast is a personal fav over here to
Edit: Also if not to late etc, it is usually done that the linear rails for the Z Axis would be installed on the Spindle plate, with the bearings being mounted to the gantry in a fixed position, making the distance from the bearing to cutter tip a variable distance rather than a fixed distance?Last edited by Lee Roberts; 27-10-2022 at 10:51 PM.
.Me
There are currently 32 users browsing this thread. (0 members and 32 guests)
BUILD LOG: El Beast - Initial design phase, comments and critique welcomed!
By Zeeflyboy in forum DIY Router Build LogsReplies: 413Last Post: 30-12-2022, 08:49 PM -
The true Beast From The East
By didineedthis in forum Machine DiscussionReplies: 8Last Post: 01-10-2021, 12:10 PM -
What desktop cnc
By fbiiburton in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 28-08-2015, 04:10 PM -
Desktop cnc, HELP
By Walkz69 in forum Machine DiscussionReplies: 1Last Post: 25-05-2013, 11:30 AM -
Does such a beast exist (using Z plane as manual-esque drill press)
By HankMcSpank in forum Computer SoftwareReplies: 0Last Post: 04-03-2010, 05:36 PM
