I've only just seen your other thread about removing the spindle and adjusting the preload, the bottom nut is just a cap that locks the bearing in place the adjustment is just on the upper and you have to slacken off the 2 locking screws first remembering to tighten them after
07-12-2022 #2
Thanks Andy. I’ve tried tightening this up and it seemed to have some effect but then the noise was more sporadic but there.
Can this be tightened up really tight? It seemed to be tight anyway before I loosened it and then tightened back up.
I need a pin spanner to do it properly.
Having said that I’m probably best doing as you did and add new bearings
Are you anywhere near me in South Yorkshire?
2.2kw spindle noise
By marbles in forum General DiscussionReplies: 11Last Post: 17-04-2020, 09:02 AM -
Denford Triac Spindle making an odd noise. Bearings at fault?
By Lieutenant Swarf in forum Denford MillsReplies: 12Last Post: 21-04-2018, 05:23 PM -
Spindle funny noise
By Millone in forum Spindles & Drive MotorsReplies: 7Last Post: 08-02-2018, 02:04 PM -
800w spindle - noise & controlling remotely
By HankMcSpank in forum Generic Chinese SpindlesReplies: 49Last Post: 17-10-2013, 06:26 PM
