Thread: motion control - advice please
09-11-2022 #13
Getting the Mesa you want in the UK will probably be tricky or end up with a heafty import charge.
See how you get on with Linux, you want to be really sure it's for you before committing. I'd want the 7I80HD I believe.
I must sdmit, I have not tried using Mach3 turn with my UC300eth. I use the ucbb with mine on ports 1&2 for all the axis signalling.
Now, for the input ports however. I use these for signalling:
https://m.aliexpress.com/item/4000386156984.html?
My controls use 24v for relays, sensors, servo, etc.
A 24vin>5vout, 24 channel, npn, plugged in to the inputs on ports 4&5.
You can also opt for a 5vin>24vout 8 channel version to use on the outputs of ports 4&5 if wanted.
There are plenty of different types of these plc boards around fairly cheap.
I'm saving port3 for a high speed version later on.
Pci or Ethernet motion control?
By Ross77 in forum Machine Control SoftwareReplies: 27Last Post: 16-10-2019, 08:27 PM -
Advice on motion control Mach 3
By Crossfixer in forum General DiscussionReplies: 5Last Post: 29-06-2019, 01:23 PM -
Motion control
By Dave_stoke in forum General DiscussionReplies: 1Last Post: 13-11-2018, 07:36 PM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
Motion Control drivers and motors
By bruce_miranda in forum Motor Drivers & ControllersReplies: 71Last Post: 27-08-2009, 09:40 AM
