    Hi.
    I’m looking for advice on how to remove the spindle from its housing.
    Please see the photos but basically I’m have a very noisy spindle (see my other thread) and I’m wanting to remove it just to check things out. I have no idea and can’t find anything online for my mill (AMA VM25L).
    Many thanks
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Can you get a clearer photo of the top?
    Going by the fact the spindle is threaded, it looks like something on the top will unscrew, but that photo is too blurry to actually make out any of the finer details.
  3. The Following User Says Thank You to m_c For This Useful Post:
    If it's a belted version: Have a look at the pdf manual for the PM25MV mill.
    https://www.google.com/url?sa=t&sour...39VMppd3bmUZIR
    If it's a geared version: Have a look at the Weiss VM25L pdf
    https://www.manualslib.com/manual/18...page=13#manual
    There are a couple of instructions or you may be able to figure it out looking at the parts lists.
  5. The Following User Says Thank You to dazp1976 For This Useful Post:
  6. #4
    Looks like a belt drive head.
    And having seen that parts diagram, the pic makes a bit more sense. You'll need to compress the washer underneath the horseshoe clip and remove the horseshoe clip.
    That should then let you drop the whole quill assembly out, and give you access to the main spindle bearing adjusting nut to fully dismantle the spindle.
  7. The Following User Says Thank You to m_c For This Useful Post:
  8. #5
    Hi all
    Thanks for all your replies on this. I will follow your instructions and take a look at the links.
    Many thanks
  9. #6
    Where can I purchase a pre tension spanner?
    I fudged something up to enable me to rotate the pre tension but it’s not sufficient. It’s a spanner similar to that of a angle grinder, there are two sizes one on each side of the bearings.
    Many
  10. #7
    Quote Originally Posted by Markie11 View Post
    Where can I purchase a pre load spanner?
    Many
  11. #8
    What you're looking for is a 'pin spanner', although personally I'd just use a hammer and suitable punch.
  12. The Following User Says Thank You to m_c For This Useful Post:
  13. #9
    Many thanks
  1. VM25L R8 mill bad noise on spindle.
    By Markie11 in forum Milling Machines, Builds & Conversions
    Last Post: 27-12-2022, 10:19 PM
  2. Has anybody used split pinions to remove backlash ?
    By Zorbit in forum Rack & Pinion Systems
    Last Post: 31-08-2020, 10:07 PM
  3. Replies: 6
    Last Post: 03-05-2017, 07:32 PM
  4. How to remove coventry easychange chuck/toolholder
    By Rabs in forum Milling Machines, Builds & Conversions
    Last Post: 06-11-2015, 07:08 PM
