Are you aware that these probes have adjustment for eliminating eccentricity (as most do)? In this case, they have 4 radial grub screws that can be used to shift the tip in X and Y. You need a dial gauge (DTI) with light tip force, then adjust the screws until there is no runout / eccentricity when you rotate the probe. You should only need to do this if (when!) you have a crash and need to replace or straighten the tip although a periodic check is sensible.
The Renishaw probes use a different system, with a ball bearing pivot under the base and 4 axial screws but to the same effect.
The trigger point for most of these probes varies slightly according to the orientation of the probe, due to the 3 internal pivots. So it's a good idea to orientate the probe in the same direction each time you use it, for consistency. That's a different issue to eccentricity.
3d touch probe
By johngoodrich in forum Tool & Tooling TechnologyReplies: 23Last Post: 24-10-2021, 06:14 PM -
Any ideas or thoughts on making a edge finder come touch off tool
By suesi34e in forum Electronic Project BuildingReplies: 26Last Post: 01-01-2020, 06:28 AM -
Edge Probe + tool length probe on same input
By Noplace in forum General ElectronicsReplies: 1Last Post: 18-06-2016, 11:12 AM -
Touch probe stylus - where to buy?
By Mad Professor in forum Marketplace DiscussionReplies: 3Last Post: 05-08-2013, 07:07 PM -
Touch Probe
By luke11cnc in forum Probing, Digitizing & ScaningReplies: 28Last Post: 31-01-2012, 01:16 AM
