Thread: Stationary Ball Screw
28-12-2009 #11
Indeed it was the X axis I was thinking about ... apologies for not making it clear. The machine I was pondering was the Steele 4 X 8 router ... he (Steele) discussed assorted methods of driving the X.
1. Rack and Pinion
2. Dual lead screw, Single Stepper, Long Belt
3. Dual Lead Screw, Twin Stepper, Slaved in Mach
4. Dual Lead Screw, Single Stepper, Dual Belt
I was wondering about a single screw 'underslung' down the centre of the X axis but was worried about the Screw sagging and whipping.
I have digested the points raised here and consider all to be valid and helpful. I will return to my planing and thinking with yet more knowledge.
Thank you all for your input.Tim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
29-12-2009 #12
I am not sure of the one you mean... have you seen the BlackToe 8x4 design - he uses a chain drive...
29-12-2009 #13
Oops sorry
I gave bum info it's a 48 X 24 inch machine. http://www.solsylva.com But when I obtained the plans it was called something else .. I was confusing it with the MechMate which I have also been looking at. Too many thoughts at once.
Smiler, If you read this it may clear up the confusion in my PM.
Once again Sorry folks.Tim G-C
29-12-2009 #14
Did a search last night and skf are selling a rotating ball screw arrangement, not cheap I bet
http://www.skf.com/portal/skf_us/hom...ntentId=290063
I also recall that someone did a mill conversion to the z-axis where they rotated the ball nut, although I am not sure what the advantage would be in that case.
Peter
29-12-2009 #15
Very similar to what the lasers are using today but the Bystronics have the nut inside the servo motor rotor making it a very compact arrangement gives it's a large ball screw and a 7HP motor.
.John S -
Advice on new table and ball screw.
By D-man in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-07-2012, 10:45 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
Ball screw mounting questions
By Redccm in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 28-01-2011, 09:29 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Ball Screw Accuracy V Price
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-01-2010, 11:55 AM
