Thread: Router Station
    Hi to all complete beginner needing some advice and help where to source drive components and control equipment to continue the next phase off my diy cnc build, the status at the moment is the table and gantry system is complete and ready for the lead screws, bearings drive motors etc, contacted a company recently but they came back with a cost of over a grand for the lead screws,mounts and couplings only, I thought they were having a laugh to much dosh for me, anyone suggest competative and reliable supplier, thanks in advance, once I figure it out will post photos of progress so far.
    scotsman
    Cheapest place for ballscrews, as far as I know, is the ebay seller 'linearmotionbearings2008'. I've bought some linear bearings from him and it was pretty good service.
    For stepper motors and good quality drivers, www.slidesandballscrews.com is your freind.
    For cheap drivers then have a look on eBay.
    Thanks Jonathan Ill give them a try and see what gives,as I have noted I have a lot to learn.
    scotsman
    Bill,
    Did you make any progress with your inquiries as to the parts you now need for your machine?
    I'm not sure how you would like to go with regards to cost, you do have the option of using standard threaded bar as your lead screws. I think we should start with these first then move on to the other parts you need. You need to give me an idea of what your intensions are for this machine.
    .Me
    Hello Lee
    I will have a budget of around £500, does this seem realistic? I would hope to fit the leadscrews using ballscrew assemblies if the budget ok, the machine will be used to cut the component parts for my model trucks.
    Bill
    Quote Originally Posted by scotsman View Post
    I think you should certainly be able to afford ballscrews for that amount. If not then you may want to consider using something similar to what I did on my Y-axis - threaded rod and an angled bearing acting as the 'nut'. It's efficient and very very low backlash.
    You will save a lot if you make the mounts for the ballnuts and bearings yourself. They all seem very overpriced to me...
    Hello Jonathan
    I was hoping to complete the project with my £500 pounds including the electronics etc, making the mounts ect will not be a problem, would a reasonable acuracy be achieved using threaded rod? not quite sure what you mean by an angled bearing do you have photos?
    Bill
  2. We are Bearing Station: Ask us anything!
    By Mark Proctor in forum Marketplace Discussion
    Last Post: 04-12-2013, 11:01 PM
  3. NEW MEMBER: Hi - I'm part of the Bearing Station team...
    By Mark Proctor in forum New Member Introductions
    Last Post: 19-04-2013, 09:07 AM
  4. FOR SALE: Weller soldering station and irons - consider any offers....
    Last Post: 01-06-2011, 10:42 PM
