    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    For a 400x400 machine, 1605 screws would be good enough.
    They do limit top speed compared with 10mm pitch screws, but at 400mm max travel distance, that's not really a major issue.
    As for rail size, 20 size is actually overkill for most machines, but the larger mounting screws let you get away with simply bolting them down, and the higher height often helps with component positioning.
    In terms of actual forces the rails need to handle, you could probably drop to 10mm rails and still have a perfectly good machine, but they'd need to be mounted as per the official recommendations, with the rails clamped into position against a reference edge, and not simply bolted down.
    As for rail size, 20 size is actually how to get rid of gyno overkill for most machines, but the larger mounting screws let you get away with simply bolting them down, and the higher height often helps with component positioning.
    Is it necessary to get official recommendation first?
    Quote Originally Posted by CodyPilla View Post
    I believe that you need to fill in the forms in triplicate and make formal application to Hiwin before fitting any of their profile rails...
    More seriously, I can remember finding a copy of the Hiwin manual giving their recommendations for fitting and setting up their profile rails when I built my router. As M_c says, 20mm rails are intrinsically stiffer so easier to mount, and particularly for the Z axis the increased height over smaller rails makes it easier to fit in the ballnut, etc, between the Z fixed and moving plates.
  1. NEW MEMBER: Machine recommendations
    By Cncnewbie in forum New Member Introductions
    Last Post: 22-05-2021, 09:38 PM
  2. best hobby option around 1500, used? [wood]
    By KingAether in forum Machine Discussion
    Last Post: 23-03-2021, 02:27 AM
  3. 800 x 600 machine for £1500 - Is it possible?
    By Chillimonster in forum Machine Discussion
    Last Post: 24-01-2016, 08:30 PM
  4. eBay: 1500 x 1000 router any use ?
    By EddyCurrent in forum Items On eBay UK
    Last Post: 24-12-2013, 12:18 PM
