14-01-2023 #4
Hi Rob,
Try the cut in air. If it keeps the zero that will tell you it's not GRBL. If it still does it I'd suggest it's potentially an electrical interference issue, otherwise it's potentially just pushing the machine too hard and dropping steps / mechanical slippage eg a grub screw not being tight enough (I noticed you have a number of pulleys and belts - make sure everything is appropriately tight but don't over tension the belts). Interference is still a possibility (the current in the spindle and motor wires will be higher when actually pushing through material) but it's the less likely bet if the in air cut works.
By the way - just seen your Instagram page from another thread. Some beautiful work!Last edited by AndyUK; 14-01-2023 at 12:35 AM.
6 axis grbl from ukcnc
By bazbalz in forum General DiscussionReplies: 1Last Post: 16-11-2021, 11:45 PM -
GRBL Sender New Interface Questions
By emarte in forum Machine Control SoftwareReplies: 0Last Post: 12-02-2021, 02:29 PM -
GRBL and UGS ??? I don't understand
By MCmec in forum General DiscussionReplies: 2Last Post: 03-01-2020, 07:14 PM -
GRBL milling stopping randomly
By Datulab in forum General ElectronicsReplies: 4Last Post: 15-01-2017, 08:52 PM -
z axis loosing steps
By ptjw7uk in forum Machine DiscussionReplies: 23Last Post: 10-05-2010, 07:38 PM
