    Hi all,
    As I'm busy with work and no longer have the time or space to run this machine, i'm looking to sell. Would alo consider selling parts seperate (control panel as a single unit), if there's more interest. Details as follows:
    General Info:
    Hours of use: Few hundered hours of hobby use (many of which were idle)
    Materials cut: Aluminium, brass, various woods, foams, plastics and more.
    Cutting area: ~700 x 400mm with Z axis of around 90mm (from spoil board (18mm thick) to spindle). There is also a 100mm overhang for taller objects at the front, so total ~800mm X axis.
    Machine construction:
    Components:
    - HIWIN 20mm rails on all axis (1000, 600, 300mm)
    - 1610 dual ball screws on X axis (1050mm long), 1605 single ball screws on Y/Z (650, 250mm)
    - All ball screws are belt driven
    Materials:
    - 4mm thick steel box section for the frame/gantry
    - 10mm steel gantry side plates
    - CNC machined aluminium Z axis and motor mounts
    - West System epoxy levelled rail base on X axis.
    Electrics:
    - 2.2kW Water cooled spindle + Huanyang VFD
    - AM882 digital drives on all axis
    - CSMIO/IP-M motion controller
    - PSU for drives + axillary PSU for others
    - 8.7Nm NEMA 34 on X axis and 3.1Nm NEMA 23's on Y/Z (all CNC4YOU)
    - Shielded cables used throughout
    Additional:
    - Mach3 license and setup files to suit this machine (can consider selling laptop too)
    - Manual valve controlled air blast setup for metal machining
    - 25L coolant system setup for spindle
    - Proximity sensors on each end of all axis for homing and limits
    - Various E-stops on the machine/control box
    Can also sell
    - Various size aluminium plates
    - Various tools/collets for the machine
    - Workshop tools (Drill press, bench grinder/sander, compressor, vibratory tumbler, ultrasonic cleaner, etc)
    Photos:
    Machine:
ID:	31631Click image for larger version.
ID:	31632Click image for larger version.
ID:	31633Click image for larger version.
ID:	31634Click image for larger version.
ID:	31635Click image for larger version.
ID:	31636Click image for larger version.
    Some machined parts:
ID:	31639Click image for larger version.
ID:	31638Click image for larger version.
ID:	31640Click image for larger version.
ID:	31642Click image for larger version.
ID:	31641Click image for larger version.
    Located in North East for collection, if anyones interested. Thanks
  1. BUILD LOG: AVOR – a steel-framed medium-size router
    By Neale in forum DIY Router Build Logs
    Last Post: 10-06-2019, 10:15 PM
  2. Large Format Steel Framed Router
    By nathandavies in forum Gantry/Router Machines & Building
    Last Post: 07-02-2016, 02:51 PM
  3. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
