18-01-2023 #1
for a past few years I've been struggling with slotting aluminum with small 3-5mm tools.
Like right now I'm machining small-ish parts from these big 2x3m 5083 H111 sheets. Cutting (essentially slotting) around the parts at 20 000rpm at 8mm/sec with cutting depth of 1.5mm with mist coolant and I just can't push the machine harder unless I up the rpms and that helps only so little.
All the calculators are suggesting I should be flying at like 20mm/sec or faster but that would either break the carbide, TiAIN coated endmill or coat it with molten aluminum within seconds. I also keep seeing these videos of people slotting at like 12-15mm/sec with 4mm endmills with no coolant and they go through the material like butter.
What am I doing wrong?
The rigidity of the machine is not a problem, neither is the spindle power I think.
Carbide burrs & small shank indexable turning tools.
By APT in forum Manufacturer NewsReplies: 0Last Post: 08-11-2016, 03:58 PM -
Burnt bit slotting MDF
By d4cnc in forum Machine DiscussionReplies: 8Last Post: 02-04-2016, 10:14 PM -
RFQ: Small aluminum milling/water cutting
By Harry Hills in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-11-2014, 01:54 AM -
slotting the edge on a cnc machine?
By wyndham in forum Machine DiscussionReplies: 1Last Post: 02-06-2011, 12:11 PM -
Collet Too lholder for small carbide tools?
By alan2525 in forum Tool & Tooling TechnologyReplies: 1Last Post: 07-04-2010, 02:13 PM
