18-01-2023 #2
I found slotting is slow with anything.
The calculators don't take into account the force involved with slotting. If machining around the outside you only have say 1/4 of the tool side engaged (woc) at half tool depth (doc). (this is what the calculators are based on). When you slot you have double the tool engagement / double the force,
ergo- you have to HALVE the calculation figures. So: half the speed and 1/4 tool depth.
That's how I figure it anyway.
I always end up halving the HSMworks calculation.
It is what it is!!!.
Milling at home I go 1/4 shallow with a 3mm. I doc at 0.75mm, 2500rpm, 300mm/min. I'm limited by my rpm.Last edited by dazp1976; 18-01-2023 at 03:07 PM.
Carbide burrs & small shank indexable turning tools.
By APT in forum Manufacturer NewsReplies: 0Last Post: 08-11-2016, 03:58 PM -
Burnt bit slotting MDF
By d4cnc in forum Machine DiscussionReplies: 8Last Post: 02-04-2016, 10:14 PM -
RFQ: Small aluminum milling/water cutting
By Harry Hills in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-11-2014, 01:54 AM -
slotting the edge on a cnc machine?
By wyndham in forum Machine DiscussionReplies: 1Last Post: 02-06-2011, 12:11 PM -
Collet Too lholder for small carbide tools?
By alan2525 in forum Tool & Tooling TechnologyReplies: 1Last Post: 07-04-2010, 02:13 PM
