Page 2 of 2 FirstFirst 12
    I've been around this stuff for far longer than I'd care to admit
    The main driver for how much you plan for replacement/upgrade will be how reliant you are on the machine.
    If you can't really afford any down time, I'd probably look at creating a completely new control box with more modern drivers, and a suitable motion controller. The controllers already mentioned are only a couple of lots of options. More modern drivers are also likely to allow you to get a bit more performance out of the machine, but you are then heading towards the rabbit hole of how much you upgrade.
    Hopefully one day I can be where you're at
    It is our only machine, so we do rely fairly heavily on it. We're not so busy that any downtime is a real killer, but the prospect of machine failure is always in the back of my mind. Everything just seems so daunting!
    No problem, let me know how you get on if you need more help. There is also a CNC Drives forum at http://www.forum.cncdrive.com/ which is very helpful.
  3. The Following User Says Thank You to JohnHaine For This Useful Post:
  4. #13
    Quote Originally Posted by JohnHaine View Post
    Excellent, thanks for that
  5. #14
    I upgraded from an old XP machine with PP to a Dell Win10 machine last year, using UC100s. (One for mill and one for lathe.) Process was painless, I just transferred the xml file that defines the machine configs, installed the UC100 Mach 3 plugin, and was away.
    Recently just did this as per your and m_c's recommendation, couldn't be happier with how it worked out. Thanks so much.
  6. #15
    Good stuff, glad to help.
  7. The Following User Says Thank You to JohnHaine For This Useful Post:
  1. Entry level Probe
    By Leadhead in forum Probing, Digitizing & Scaning
    Last Post: 09-10-2013, 07:55 AM
  2. help needed going to the next level
    By luke11cnc in forum Computer Software
    Last Post: 20-09-2012, 08:53 AM
  3. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  4. NEW MEMBER: Just joined, hobby level
    By cncgcg in forum New Member Introductions
    Last Post: 03-12-2011, 02:32 PM
  5. Level Y Axis
    By sfallan in forum Machine Discussion
    Last Post: 26-09-2010, 12:52 PM
