  1. #2
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    First thing I'm going to ask, is do you have a backup of the Mach3 config files?
    The most likely thing to fail is the PC, so make sure you have a back up of all the critical files. Main one is the machine config (.ini file IIRC - it's been a while since I've used Mach3!), and the macro directory for that machine. Easy option is just copy the entire Mach3 directory to a memory stick, but upload the critical files somewhere safe as well.
    Next would be to make sure you have a plan should the PC/control box fail.
    Is the control box parallel port, or some form of USB controller?
    I'd probably start by making a wiring diagram of the existing setup, as should something fail, it then removes a big part of diagnosing/replacing things.
    Other than that, the mechanics should be pretty simple. Given it's a MD machine, they're not likely to be ideal, but should be simple to identify any problems and find replacement parts.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. Entry level Probe
    By Leadhead in forum Probing, Digitizing & Scaning
    Last Post: 09-10-2013, 07:55 AM
  2. help needed going to the next level
    By luke11cnc in forum Computer Software
    Last Post: 20-09-2012, 08:53 AM
  3. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  4. NEW MEMBER: Just joined, hobby level
    By cncgcg in forum New Member Introductions
    Last Post: 03-12-2011, 02:32 PM
  5. Level Y Axis
    By sfallan in forum Machine Discussion
    Last Post: 26-09-2010, 12:52 PM
