    hello please
    3 positec 5 phase mini motors and a pac controller
    3x little 5 phase motors - they dont like the mach i think as they are a 10 wire motor
    about 45mm long with a 60mm bolt doofer - so not like nema 23 which is 57mm
    erm
    the controller is a three axis affair with cards that kind of plug in
    again 5 phase
    ran from a 24v psu
    thanks
    erm has a breakout board of the rs232 variety
    a power card
    50 quid the lot
    i will have another one next weekend too
    plus me thinks a 2 axis foam cutting machine, smallish
    very nice
    located in the fulham = i.e. collection only
    postage is £150
    i am cutting the cables from the motors and using the rs232 ends to my new drives and motors
    i just bought tint nema 23's 8 wire and some little drivers - why I don't know - or I know I can get it to work.
    this maybe really easy for you
    came from a high end mini mill
    ta
    Pics of the three phase motors/controller ?
    3 motors no cables - i am using them on my new motors and drivers
    i could leave it all ready to run IF you vcan work out the inputs into the rs232 port on the controller and sell you the unmessed with cabling
    the rs232 in is only 11 pins so you can work out the pulses to that and the torch controll you are golden really
    I can - or do not wish to bother = i am cutting off the cables and using the rs232 ends to my new drivers - or I could just get new wire and charge you more money
    then you have a sweet little 5 phase machine 500 pulses per rev
    i bet you could simply plug it into a rs232 port on a computer and run mach through it.
    i have just picked up the other machine
    its 4 axis
    similar looking controller and drive set up
    with older but the same motors
    circa i think 1998
    will do a deal if you buy the lot
    thanks
  1. AT1 Single Phase to Three Phase Penske Spindle Woes....
    By Cozza in forum Spindles & Drive Motors
    Last Post: 14-07-2021, 10:01 PM
  2. Replies: 0
    Last Post: 10-05-2021, 05:32 PM
  3. VFD 220v single phase to 380v three phase.
    By Richard in forum General Discussion
    Last Post: 14-12-2020, 11:19 PM
  4. Positioning three phase induction motors.
    By Agathon in forum Motor Drivers & Controllers
    Last Post: 23-04-2020, 01:02 PM
  5. Panasonic 3 phase driver running on 1 phase?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 10-05-2012, 11:21 PM
