Thread: Cheap Tool Length Sensor Options
Provided the probe is using a reasonable quality switch, switches are generally fairly repeatable.
Plus for woodworking, you generally don't need that high an accuracy.
I'll admit I personally use a mechanical tool setter on my mill, despite having a circuit board made up for adding a tool length sensor, but it does have a toolchanger, so I only have to set tools when changing them in holders.
I probably wouldn't get too hung up on emergency back up switches. Just make sure you have a screen that shows when the switch is actuated, and give it a quick press manually to check it's working before running the automatic tool setting routine.
Sometimes you can overthink things (I know I can be bad for it!), but simple is more often than not more than adequate.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Tool height sensor.
By Ollie78 in forum General DiscussionReplies: 10Last Post: 27-06-2019, 09:32 PM -
WinNc Sinumerik 810D/840D can't accept tool length compensation
By Maxiscnc in forum Siemens (Sinumerik)Replies: 5Last Post: 25-02-2019, 01:45 PM -
How to use the tool height probe sensor?
By jhonansaro in forum Laser Machines & BuildingReplies: 4Last Post: 04-05-2018, 09:21 AM -
Relationship between Guide rail length and ballscrew length
By CharlieRam in forum Rails, Guideways & BearingsReplies: 6Last Post: 11-07-2014, 11:37 PM -
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM
