Originally Posted by m_c If the axis movement is accurate over 150mm, then it's very likely a combination of cutter/machine deflection, and backlash. A DTI would let you know where the problem lies. Thanks for the reply m_c, can you explain how to use the "DTI" in this situation please?
Forum Rules
