Thread: stuck need help
Hi all
any ideas how to do a fix . My cnc has been turned off for about 12 months due to personal circumstances and now i am back at it , so turned it on and everthing works but the machine aint moving , the steppers are exited and i write a program and it loads to mach 3 but i can not do anything with the machine ( jog ) nothing has been changed or anything it just wont move now any ideas anyone
please.
20-02-2023 #2
Have you checked that there is power to the control unit and steppers?
20-02-2023 #3
Hi
Yes there is power to the unit as the machine fires up ok and the stepper motors are all locked ready to work
20-02-2023 #4
Is the esto button flashing?
20-02-2023 #5
Hi There
Yes the estop is flashing
20-02-2023 #6
in my mach3 when i load mach3 a window comes up asking me what port i want to use it has never done that before and i have tried using every port but still no movement
20-02-2023 #7
What motion controller do you have? Parallel port? If the estop is flashing try clicking on it
20-02-2023 #8
Am using a data cable
20-02-2023 #9
Just clicked on the estop and still no movement .
When i load mach3 a window comes up that says YOUR SYTEM IS SHOWING MORE THAN ONE CONTROL DEVICE PLEASE PICK THE ONE YOU WOULD LIKE THIS PROFILE TO USE.
NORMAL PRINTER PORT OPERATION
BSMOTION _V2.0
OR NO DEVICE
20-02-2023 #10
What sort of data cable and where is it connected? But try selecting the second.
NEW MEMBER: Hi there Old D&T teacher stuck !!
By shindax in forum New Member IntroductionsReplies: 2Last Post: 27-09-2019, 11:12 PM -
Stuck morse taper
By dfox1787 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 13Last Post: 12-09-2018, 02:00 PM -
Laptop stuck in BOotmgr missing
By dazza in forum Laptops & TabletsReplies: 8Last Post: 28-02-2016, 07:08 PM -
feedrate stuck on low
By routercnc in forum Machine DiscussionReplies: 1Last Post: 24-04-2014, 10:24 PM -
250mW LASER stuck on
By korky in forum General ElectronicsReplies: 10Last Post: 12-07-2009, 10:47 PM
