Thread: stuck need help
Hi all
any ideas how to do a fix . My cnc has been turned off for about 12 months due to personal circumstances and now i am back at it , so turned it on and everthing works but the machine aint moving , the steppers are exited and i write a program and it loads to mach 3 but i can not do anything with the machine ( jog ) nothing has been changed or anything it just wont move now any ideas anyone
please.
20-02-2023 #2
Have you checked that there is power to the control unit and steppers?
Hi
Yes there is power to the unit as the machine fires up ok and the stepper motors are all locked ready to work
20-02-2023 #4
Is the esto button flashing?
Hi There
Yes the estop is flashing
in my mach3 when i load mach3 a window comes up asking me what port i want to use it has never done that before and i have tried using every port but still no movement
20-02-2023 #7
What motion controller do you have? Parallel port? If the estop is flashing try clicking on it
Just clicked on the estop and still no movement .
When i load mach3 a window comes up that says YOUR SYTEM IS SHOWING MORE THAN ONE CONTROL DEVICE PLEASE PICK THE ONE YOU WOULD LIKE THIS PROFILE TO USE.
NORMAL PRINTER PORT OPERATION
BSMOTION _V2.0
OR NO DEVICE
Am using a data cable
20-02-2023 #10
What sort of data cable and where is it connected? But try selecting the second.
NEW MEMBER: Hi there Old D&T teacher stuck !!
By shindax in forum New Member IntroductionsReplies: 2Last Post: 27-09-2019, 11:12 PM -
Stuck morse taper
By dfox1787 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 13Last Post: 12-09-2018, 02:00 PM -
Laptop stuck in BOotmgr missing
By dazza in forum Laptops & TabletsReplies: 8Last Post: 28-02-2016, 07:08 PM -
feedrate stuck on low
By routercnc in forum Machine DiscussionReplies: 1Last Post: 24-04-2014, 10:24 PM -
250mW LASER stuck on
By korky in forum General ElectronicsReplies: 10Last Post: 12-07-2009, 10:47 PM
