27-02-2023 #3
If you run the same gcode file twice, is the error in position exactly the same, or similar-but-different? Is it Y or Z (as mentioned above)? Does it make a difference if you are actually cutting or "air-cutting" - i.e. above the work? How complex is the gcode file - a simple outline, for example, or a lot of small intricate moves like engraving? At the end of a cut, does the machine position display say that the tool is out of position or is the display correct but the tool not in the right place?
Need quite a lot more info to start diagnosis!
RFQ: CNC 5 Axis 450mm Y x 250 X x 250 Z Precision machining H12+
By AcroCruiserF11AC in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-08-2019, 10:11 PM -
BUILD LOG: DIY Marble - Metal Machining 3 axis CNC Router
By Halbmond in forum DIY Router Build LogsReplies: 10Last Post: 10-06-2018, 12:14 PM -
4 axis machining software
By edgas10 in forum CAD & CAM SoftwareReplies: 14Last Post: 17-02-2016, 08:00 PM -
4th Axis CAM Software Multi Sided Machining
By alan2525 in forum Computer SoftwareReplies: 0Last Post: 18-02-2010, 12:44 AM
