    it is a tad nippy, but not too bad... with the fan heater on medium its about 15degC in this weather (4degC outside) if I put it on full it only goes up another degree so I dont bother.
    Was in the workshop today and started burning off Christmas rubbish in the stove, just above the stove is a thermometer and after it got up to 48 C I thought it prudent to back it off a couple of gears.
    A nice 30 is very nice this weather, mind you when it's burnt down a bit it soon gets very cold with all the machines and metal in the shop.
    I keep about 7 tonnes of steel on stock at any one time and that takes a large amount of heat to raise it 10 degrees.
    John S -
    I used to work in a workshop with no overnight heating, we had a radial drill which weighed about 10 ton. when this got cold it was like a giant radiator in reverse sucking in any heat we could get in the building.
  1. Save my sanity - 1050 grade aluminium
    By Isaac in forum Metal Finishing Techniques
    Last Post: 03-06-2014, 01:45 AM
  2. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  3. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 09:33 AM
  4. sanity check - constant running, loads and more
    By dsc in forum Stepper & Servo Motors
    Last Post: 26-11-2012, 12:26 PM
  5. Toroidal transformer voltages - sanity check needed!
    By m_c in forum General Electronics
    Last Post: 03-10-2011, 08:34 PM
