    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hi all,
    Thought I'd ask the hive mind in case anyone has a quick answer.
    I'm after a small quantity of thin medium carbon steel in sheet (0.5/0.7mm) that I'd like to press form and harden/temper for a bit of spring. Trouble is I only need a bit (let's say 20 pieces 80x85) - short of getting lucky with offcuts, anyone know where I can source small quantities of CS70 / EN8 etc?
    Many thanks!
    Wal.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 7-8 years. Has a total post count of 460. Received thanks 73 times, giving thanks to others 20 times.
    Are you sure you want EN8? Sheet spring steel tends to be a different material. Something like this perhaps? https://www.ebay.co.uk/itm/314119617...3ABFBMpIf4ieVh
  3. The Following User Says Thank You to Muzzer For This Useful Post:
    Wal's Avatar
    Hi Muzzer,
    Hey - I'm not sure what I want..!
    Yep, I understand that EN8 is a mild steel, but it has a 0.4% carbon content (making it suitable for heat treatment), is machinable and reasonably ductile so it ticks the boxes.
    The link that you provided - in its quenched state, is that not going to be a bit of a nightmare to work with - both machining and forming? Would it not need annealing prior to working?
    Wal.
  5. #4
    Muzzer's Avatar
    Sorry I didn't notice that. Ideally it would be tempered or annealed presumably, so that you can work it.
    Disclaimer - my only experience of springs has been with materials that were developed for use in springs but they were almost exclusively helical and made from wire.
  6. #5
    Wal's Avatar
    Had a dig through one of my drawers and found some old 0.5mm shim-stock (304 stainless). It's pretty springy and looks like it might do the job without the need for any heat treatment - provided I can cut it and that it responds well to the hand-tools I've made to form it.
    This is how the clip looks fully formed - the secondary ops to bend the arms don't need much force, just hoping that the big bowl in the middle forms as well as it has in the generic 1mm thick CR4 used for the tests.
    Wal.
  1. BUILD LOG: AVOR – a steel-framed medium-size router
    By Neale in forum DIY Router Build Logs
    Last Post: 10-06-2019, 10:15 PM
  2. RFQ: Need some small parts cut from Carbon fiber sheet
    By Devil_WAH in forum Projects, Jobs & Requests
    Last Post: 23-02-2017, 07:44 PM
  3. RFQ: Very small plastic parts - mid quantities
    By Ellis in forum Projects, Jobs & Requests
    Last Post: 23-04-2015, 11:26 AM
  4. WANTED: Suppliers of small quantities of BSW screws etc..
    By irving2008 in forum Items Wanted
    Last Post: 19-07-2008, 09:55 PM
