    Fgc's Avatar
    Lives in London, United Kingdom. Last Activity: 18-12-2017 Has been a member for 8-9 years. Has a total post count of 12.
    Dear all
    I am new to using the PC Turn 55 running Camconcept software connected via Ethernet.
    I have not been able to get the spindle to spin up. I do not know what I am doing wrong in inputting spindle speed. When I attempted to run a program, the lathe turret will rotate to the correct tool and move itself into position and then I can hear a soft high pitch sound from the lathe followed by this message "Turning Cycle 6014 No main spindle speed".
    I have input the spindle speed for roughing and finishing in the tools section. Am i missing something?
    The Emco Camconcept user manual is the absolute worse manual I have ever come across. it does not explain anything!
    Please help. I cannot get the spindle to spin.
    frank
    A birt late to reply to this. I had a similar problem, same machine.
    I found the relay that controlled the spindle was a bit sticky. If you activate any of the safety switches a few times it might jolt the relay back into action. Also check the postiton of the delt on the spindle pulleys, I had an issue where I was asking the lathe to spin faster than the motor could with the belt position. This resulted in the spindle error. The spindle would attempt to get up to speed then fail as it couldn't go fast enough.
    Hope that helps
    Lee Roberts's Avatar
    Lives in Milton Keynes, United Kingdom. Current Activity: Viewing Admin Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,990. Received thanks 250 times, giving thanks to others 829 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Did you manage to sort this out Frank ?
  1. Emco PC120 Turn
    By Chaz in forum Emco Lathes
    Last Post: 14-08-2017, 09:47 AM
  2. EMCO Concept mill error message
    By kumar in forum Machine Discussion
    Last Post: 03-06-2016, 02:59 AM
  3. CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
    By andre13442 in forum Conversion Build Logs
    Last Post: 14-01-2016, 12:14 PM
  4. Emco C5 spindle motor control
    By GeoffV in forum Motor Drivers & Controllers
    Last Post: 19-03-2014, 04:20 PM
  5. EMCO Spindle Control
    By Pete92 in forum Spindles & Drive Motors
    Last Post: 06-11-2013, 10:20 PM
