    Hi Folks,
    I came across this the other day:
    https://beacon3d.com/product/beacon/
    Its an eddy current sensor that can quickly map the bed of a 3D printer - Has anyone got any experience? Wondering if it could be a useful 3D probe replacement. Looks to have massive advantages of speed (so you could scan a much higher resolution map) but needs to scan conductive surfaces and be placed away from magnets on the gantry/spindle. I could see it being useful for metal work....
    Video for interest:
    https://www.youtube.com/watch?v=Gs6UC2xK5t0
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 8-9 years. Has a total post count of 490. Received thanks 81 times, giving thanks to others 27 times.
    Those and the similar capacitative or inductive proximity sensors are great for things like limit and home switches. There was a demo video posted on the forum quite a few years ago showing how consistent they were. However, I would not use one as a replacement for a 3D sensor as they are not going to pick up fine detail. My 3D printer uses one to check bed level but of course that is sensing against a flat object which is ideal.
    I have a fairly cheap and cheerful 3D probe that came with my second-hand CNC mill so when I needed to probe and map a surface to replicate a raised design, I just made a new probe for it with a relatively sharp tip to be able pick up detail, especially close up to almost vertical edges of features. I rewrote the probing macro (under Mach3 which I was using at the time) to speed things up a bit and it all worked pretty well. A sensor like the one shown would not have done the job.
    I guess this is only relevant to 3D printing?
    How do you know your gantry is moving in a perfect plane? As I see it you are only measuring the distance between the gantry and the bed not absolute plane
  1. Mach4 screw mapping
    By Husky1 in forum Artsoft Mach (3 & 4)
    Last Post: 14-12-2020, 10:14 AM
  2. BUILD LOG: Ready Steady Eddy
    By EddyCurrent in forum DIY Router Build Logs
    Last Post: 05-08-2016, 11:44 AM
  3. Robot precision projection mapping
    By Musht in forum General Discussion
    Last Post: 10-10-2013, 03:41 PM
  4. Height Mapping?
    Last Post: 26-10-2012, 11:40 PM
  5. Mapping out project...
    By mdre83 in forum Probing, Digitizing & Scaning
    Last Post: 16-01-2009, 12:24 AM
