Thread: Drilling into Steel
Hi, Guys, better let you know what I am usige first.
I have one of those Chinese 6040 machines, which I have made some alterations, those being a 12mm steel base, and 2.2kw spindle.
I am wanting to drill a number of holes into the steel base which I will thread these will hold down the spoilboard.
My questions are, is it possible ? if so, what is the best process to use ? I hope that covers it. Thanks.
19-04-2023 #2
What is the slowest speed of your spindle? The obvious way would be to pop a drill in the chuck and off you go but in steel say a 5mm hole for an M6 hole would need a speed no more than 1000rpm I'd guess. As for tapping this would best be done by hand as I doubt the machine would do rigid tapping. If the min spindle speed is too high I think your best approach would be to pop the base on a drill press.
25-04-2023 #3
I wouldn't try and drill steel with such machine...
If I were you, I would use the 6040 to spot all the holes (To give you the exact location)
using a solid carbide 60 degree spot drill bit. That should be within the capacity of the machine no problem...
Then finish the drilling on a pillar drill.
RNR
Drilling Machine
By jamesthomsan in forum Machine DiscussionReplies: 1Last Post: 03-01-2020, 12:10 PM -
Drilling holes on cnc
By dfox1787 in forum Machine DiscussionReplies: 27Last Post: 26-05-2018, 05:21 PM -
High Speed Spindle - Drilling & Mild Steel
By Chaz in forum Spindles & Drive MotorsReplies: 22Last Post: 29-07-2017, 07:09 AM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
RFQ: CNC drilling/tapping
By Wal in forum Projects, Jobs & RequestsReplies: 2Last Post: 17-11-2013, 07:13 PM
