Hi for everyone
after big boom on the first VFD.
I'm trying to marry the New vfd with same characteristics ( 220 v / 380v 2.2kw CHINT) and the two spindles with no support no information no data sheet....
according to mr google... It's :
2.2kw
380v
24000rpm
400Hz
2 pole
and I have set the Motor Stator Impedance to 6 homs.
Everything went well
But i noticed two things
1) the display shows negative values
2)strange sounds like an old radio
PS I am a mechanic so electricity is a bit difficult for me.
it is a machine for smoothing the edges of wooden plates.
it's my brother's machine...i appreciate your help and sorry for my bad English
Envoyé de mon A1601 en utilisant Tapatalk
24-07-2023 #2
When a VFD displays negative values, it often indicates a reverse rotation direction. Reversing the direction is usually a simple adjustment in the VFD's settings.
Now, let's address the strange old radio-like sounds. These peculiar noises can be attributed to electrical noise interference. When a VFD operates, it generates harmonics and electromagnetic interference, which can manifest as audible sounds resembling static from an old radio. Some VFDs have built-in motor filters that can be enabled to reduce noise. Check if your CHINT VFD has this feature and activate it if available.
New VFD will only display frequency, not RPM
By Smiffy in forum Generic Chinese SpindlesReplies: 8Last Post: 01-04-2022, 02:50 PM -
Suggested PWM frequency for a minimal Novamill conversion
By GND in forum Denford MillsReplies: 5Last Post: 04-04-2020, 12:50 AM -
High frequency vfd 1500hz
By assadi in forum Spindles & Drive MotorsReplies: 0Last Post: 28-08-2018, 04:12 PM -
Configuring Altivar 12 frequency regulator for PID control
By vesilp in forum Spindles & Drive MotorsReplies: 4Last Post: 28-01-2017, 04:26 PM -
Looking for sound advice
By PixelsnPrint in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 02-04-2014, 11:03 PM
