    I've built a rack and pinion and a HTD belt drive cnc before but have wanted to build a ballscrew system for a while. Especially as its small the parts should be less expencive. I'd have thought RM1605 ballscrew which seems very common would be fine given that the Y axis travel is only 700mm however RM2005 might be better or just overkill. Also do I need two ballscrews on the Y or could I use just one?
    Yes your right about the backlash, it'd need to be very low ARC sec gearboxes (expencive) or 5:1 belt reduction which I use on the rack and pinion.
    Good to hear you machine corian at 5k, now that is slow. I guess its a fairly high torque spindle/machine.
  2. Quote Originally Posted by marbles View Post
    Not particularly I think. Half-horsepower (375W) dc motor running at spindle speed.
  3. The Following User Says Thank You to JohnHaine For This Useful Post:
  1. Solid state relay for ON/OFF VFD
    By Edward in forum General Electronics
    Last Post: 07-09-2017, 09:49 PM
  2. solid cam post processor help
    By kell in forum Solidworks
    Last Post: 02-06-2017, 05:43 AM
  3. 3d carving oak
    By Mikeb in forum Woodwork Discussion
    Last Post: 24-03-2014, 10:22 AM
  4. V bit carving
    By Mikeb in forum Tool & Tooling Technology
    Last Post: 20-02-2014, 04:52 PM
  5. NEW MEMBER: Hello - I'm looking to CNC solid body guitars.
    By JimH in forum New Member Introductions
    Last Post: 15-02-2011, 05:06 AM
