02-07-2023 #13
The bearing blocks were greased last week when I did the ballnut without any luck.
I'll upload some pictures of it tomorrow but the x axis is a piece of 120 x 60 mm aluminium extrusion with 8 mm walls.
The rails are positioned on the top and bottom with the ballscrew on the back with 20mm aluminium plates forming a box around around which seemed like an unusual design so I did try to see if it would twist when I first got it. I couldn't get it to twist, rack or alter shape at all. I've also made sure everything is square.
I'll try it again tomorrow just in case and also check each block when they're disconnected from everything else.
Multimeter LCD displaying all settings need some advice - fault
By RobC in forum General ElectronicsReplies: 9Last Post: 11-06-2021, 01:06 PM -
Advice on 4th Axis
By OMLCNC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-02-2021, 10:17 AM -
Bridgeport Romi EZ Path S - Axis Drive Fault
By Nemo1966 in forum Machine DiscussionReplies: 0Last Post: 12-02-2018, 01:13 PM -
555 timer circuit to control 12v solenoid air valve (for intermittent bursts of air).
By Wal in forum General ElectronicsReplies: 13Last Post: 12-05-2017, 09:10 AM -
Axis resolution advice
By cweeks in forum Linear & Rotary MotionReplies: 8Last Post: 23-09-2010, 06:10 PM
