The Voltage written on a modern stepper is usually down around 1 Volt. They don't expect you to use 1 Volt, they expect you to use maybe 36V to overcome the coil inductance and then limit the current so it doesn't go pop.
There was a time, long ago, when people used the L200 stepper driver chip and 6 or 12V steppers were quite normal.
If you can turn the motor with 6V applied then maybe you have coils in series? Even then it doesn't sound at all right.
What current to use for MAE HY200 3424 0310 Stepper Motor?
By Mxml in forum Stepper & Servo MotorsReplies: 2Last Post: 29-06-2023, 08:38 PM -
Help - Current For Stepper Motor Driver AM882 - ProTuner
By PaulP in forum General DiscussionReplies: 21Last Post: 22-08-2022, 08:32 AM -
Low current stepper drivers with screw terminals?
By m_c in forum Stepper & Servo MotorsReplies: 4Last Post: 05-08-2018, 06:57 PM -
Current favourite stepper drivers
By GND in forum Motor Drivers & ControllersReplies: 8Last Post: 05-03-2017, 11:52 AM -
Calculating Stepper Motor Power? Strength?
By antsals in forum General DiscussionReplies: 2Last Post: 11-07-2011, 12:18 PM
