Page 2 of 2 FirstFirst 12
    Lives in Plymouth, United Kingdom. Last Activity: 15 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    In my case, I have spare input ports on my Arduino so no need to emulate a pot - I'm using the pot connected to the Arduino's ADC anyway to give an internal 0-255 to represent desired temperature - so using the processor means a SMOP(*) only needed.
    For the Hitachi processor, though, not so sure. Had a quick look at data sheet last night (my, that thing's old!) and it looks as if it has the potential for a couple of interrupt lines but not sure if they would trigger on level change in either direction or just one. I would try to do as much as possible in the CPU and avoid external circuitry, though.
    (*) Simple Matter Of Programming
    Awww! But I like external circuitry
    Not sure that it's quite that easy! If you look at the data patterns there is no simple link between either data line and direction. And if you only interrupt on one data line, you will miss half the transitions..
    You configure the interrupt on either leading or trailing edge - so the interrupt occurs on a transition on one phase - the other phase is steady state at this point. The interrupt is essentially the "clock" to increment or decrement the counter. The state of the second phase, either 0 or 1 determines whether to increment or decrement.
  1. Spindle pulses on shutting down.
    By John11668 in forum General Electronics
    Last Post: 22-08-2020, 11:45 AM
  2. Basic 540 CNC. Motors skipping pulses?
    By Skydeals in forum General Electronics
    Last Post: 18-10-2014, 06:56 PM
  3. Do you make stuff with knobs on?
    By D.C. in forum General Electronics
    Last Post: 20-02-2013, 11:04 PM
  4. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
  5. G-Code into stepper driver pulses?
    By HankMcSpank in forum Computer Software
    Last Post: 09-01-2010, 12:55 PM
