    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    As it's only polystyrene, cutting forces would be very minimal, so well designed lightweight should be more than acceptable.
    Robot control is all about kinematics.
    As long as a robot could be controlled by fairly common steppers/servos, there are controller options about that could handle it.
    If it's something you did want to consider, I'd suggest having a look at Dynomotion, as their default CNC software can be made to handle kinematics, and TomK (Who run's Dynomotion) does like kinematics.
    The major benefit of having a good kinematics setup in the controller, is you can program the machine using conventional Cartesian (XYZ) moves/positions, and the controller will handle converting that to the non-linear movements that something like a robot arm needs.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #2
    Thank you, do you mean look into Dynomotion to make a controller for an industrial robot or for the one I've drawn up?
  1. Guitar Building with my JazzCNC machine
    By BeeceUK in forum Woodworking Project Showcase
    Last Post: 26-09-2021, 10:53 PM
  2. NEW MEMBER: Not building buying a machine
    By theceo in forum New Member Introductions
    Last Post: 31-03-2016, 07:12 PM
  3. FOR SALE: Various machine building, cnc related bits
    Last Post: 05-06-2015, 09:10 AM
  4. Building 2nd machine smaller one
    By Timo in forum Gantry/Router Machines & Building
    Last Post: 10-06-2014, 03:10 AM
  5. NEW MEMBER: CNC and other Machine Building Berlin
    By Andikid in forum New Member Introductions
    Last Post: 07-10-2010, 11:30 PM
