07-08-2023 #1
I have this spindle from VEVOR and is air cooled and this VFD .
https://eur.vevor.com/spindle-motor-...p_010384570403
After reading the manual I think I made all setups correct but my spindel get hot after 20min of running.
User guide is here:
https://www.et.byu.edu/~sorensen/A2%20VFD%20Manual.pdf
I use this spindle by starting manually with panel buttons START/STOP
I don`t know if is right to be that hot ( I don`t have thermometer but cannot keep fingers on it for 5 seconds). I have another spindle from vevor (400w) but it is running warm.
It is used to carve styrofoam (polystyrene)
Sorry for my english but is not my native language...
Mybe somebody knows much better this kind of VFD`s and help me to stup right.
Thank you.
07-08-2023 #2
The first one you link to is a water cooled spindle, you need to have coolant flowing through it. It has no air cooling at all.
08-08-2023 #3
If you read carefully, you would have seen that it clearly says AIR COOLED. I couldn't find an image of an air-cooled one.
08-08-2023 #4
Oh I read carefully enough thank you, you failed to mention you couldn't find a picture of an air cooled one. Good luck.
220v VS 380v Spindle Difference
By BigBrand in forum Spindles & Drive MotorsReplies: 3Last Post: 25-01-2021, 03:27 PM -
VFD YL620-A2.2KW 220V and 2.2KW water cooled spindle settings
By A11an in forum Spindles & Drive MotorsReplies: 6Last Post: 13-12-2020, 07:56 PM -
Water cooled vs Air cooled spindle for wood
By Bucks in forum Machine DiscussionReplies: 5Last Post: 06-02-2017, 01:58 PM -
Water cooled / air cooled 2.2kw spindle
By suesi34e in forum Generic Chinese SpindlesReplies: 15Last Post: 25-02-2015, 04:57 PM -
eBay: 300W 12V-48V DC High speed air cooled spindle motor for engraving milling
By Swarfing in forum Items On eBay UKReplies: 0Last Post: 16-06-2013, 01:33 PM
