Thread: Static buildup enquiry
14-09-2023 #1
Hi there,
I’m machining a lot of solid surface at the moment and I’ve noticed a lot more static charge building up. I’m getting some quite large arcs during vacuuming, the vacuum ON/OFF switch in particular.
How can reduce this static build up?
Many thanks
14-09-2023 #2
Interesting problem. I assume you are machining plastic? Not something I do much of but perhaps there are known / effective countermeasures. At the machine level, I expect they would amount to adding various grounding connections to nearby conductive surfaces but that's only a guess.
There seem to be various additives that are added to plastic to reduce buildup (can you buy antistatic versions of your materials?). I know that carbon fill in plastic can improve the conductivity but that's only any use if you are making black parts. I also see references to "ionising blowers" and "ionising guns" etc which sound like a more high tech (expensive) approach.
The Following User Says Thank You to Muzzer For This Useful Post:
14-09-2023 #3
Long a problem with vinyl records. Google for Zerostat guns.
The Following User Says Thank You to JohnHaine For This Useful Post:
4th axis brake enquiry
By marbles in forum Linear & Rotary MotionReplies: 17Last Post: 12-05-2020, 09:02 AM -
Safe Z and Go to Zero enquiry
By marbles in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 24-04-2020, 03:44 PM -
Static converter to power a cnc Lathe???
By Ross77 in forum General ElectronicsReplies: 6Last Post: 28-02-2018, 04:33 PM -
Massive Static sparks in dust shoe
By mturneruk in forum General DiscussionReplies: 4Last Post: 20-01-2016, 12:01 AM -
RFQ: Early enquiry
By boldford in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-07-2012, 06:40 PM
