  1. #2
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 12 Hours Ago Has been a member for 8-9 years. Has a total post count of 490. Received thanks 81 times, giving thanks to others 27 times.
    Interesting problem. I assume you are machining plastic? Not something I do much of but perhaps there are known / effective countermeasures. At the machine level, I expect they would amount to adding various grounding connections to nearby conductive surfaces but that's only a guess.
    There seem to be various additives that are added to plastic to reduce buildup (can you buy antistatic versions of your materials?). I know that carbon fill in plastic can improve the conductivity but that's only any use if you are making black parts. I also see references to "ionising blowers" and "ionising guns" etc which sound like a more high tech (expensive) approach.
  2. The Following User Says Thank You to Muzzer For This Useful Post:
  1. 4th axis brake enquiry
    By marbles in forum Linear & Rotary Motion
    Last Post: 12-05-2020, 09:02 AM
  2. Safe Z and Go to Zero enquiry
    By marbles in forum Artsoft Mach (3 & 4)
    Last Post: 24-04-2020, 03:44 PM
  3. Static converter to power a cnc Lathe???
    By Ross77 in forum General Electronics
    Last Post: 28-02-2018, 04:33 PM
  4. Massive Static sparks in dust shoe
    By mturneruk in forum General Discussion
    Last Post: 20-01-2016, 12:01 AM
  5. RFQ: Early enquiry
    By boldford in forum Projects, Jobs & Requests
    Last Post: 30-07-2012, 06:40 PM
