Thread: Axyz millennium
10-10-2023 #41
Hi again
Well I made sure all the boxes were ticked, I changed from offset to raster , I have cut direction on climb and using a 6mm end mill cutting 4mm deep and she still only cuts a single line down to the set depth.......mystified
11-10-2023 #42
I wouldn't use climb cutting without a fairly powerful reason.For specific Vectric advice I think you would have a wider range of experience to call on at either of these:
https://forum.vectric.com/
https://www.cnczone.com/forums/vectric/
11-10-2023 #43
I'm a Vectric user but have never seen this problem. Any chance of screen shots showing all the configuration parameters when you set up the toolpath?
But the more specialist forums might help, as suggested above.
12-10-2023 #44
Got it.
As always I am sure I am not the only one that creates our own problems because we try to find a reason and try to sort a problem that we miss the obvious that is staring us right in the face Routerdriver. Man I was getting stressed over this simple problem, I know it sounds bad but I didn't even think ( shameful ) to ask vectric support, don't know why either but in 5 minutes it was all sorted and all working perfect.
Now I just need to sort out the optical box that sends it to the machine but it works .
12-10-2023 #45
Hi Neale
All sorted bud
What I was doing is on my old cnc using mac3 I would write a program in vectric and send it to the chinky machine and it would just cut a pocket and that's what I was used to doing, but on this new machine using axyz stuff , I write the program in vectric to do the pocket and now I have to save two toolpaths and what was happening is I was only sending one toolpath and that was the final cutting toolpath not the clearing toolpath, the problem was right in front of me and didn't see it , but all sorted now and I am hanging my head in shame over it ,
Thank for the imput bud
Pete
12-10-2023 #46
I can understand the problem - I use both Vcarve (for 2D machining) and Fusion 360 (for more complex "engineering" jobs) and they handle this kind of thing differently so you have to stop and think each time! I have just made a brass plaque - engraved, holes drilled, outside cut and chamfered - which involved 5 different tools. So 5 separate toolpaths as Vcarve can't cope with multiple tools in one gcode file unless it believes the machine has a toolchanger (as far as I can see) where F360 can mix; my machines are set up to pause for a manual tool change so that works for me.
I presume that you are using different tools for roughing and finishing? If you are using the same tool, you should be able to combine them in one file.
But you've found the trick, so it won't happen again! Probably
12-10-2023 #47
13-10-2023 #48
How about a link to the thread on the Vectric forum?If somebody else comes along with the same problem,we can send them straight there.
The Following User Says Thank You to routerdriver For This Useful Post:
13-10-2023 #49
14-10-2023 #50
You could copy and paste the url of the page with the answers.In the meantime,I'm guessing that you hadn't ticked the boxes for all the sequences when you post processed.
There are currently 13 users browsing this thread. (0 members and 13 guests)
AXYZ new software ??
By cncbeginner in forum AXYZ RoutersReplies: 15Last Post: 13-10-2024, 07:28 PM -
In Need of AXYZ DNC exe pls
By Arpad in forum Machine Control SoftwareReplies: 1Last Post: 27-11-2023, 05:14 AM -
AXYZ 3000 Router - AXYZ-USB-1A - Drivers
By soap47 in forum AXYZ RoutersReplies: 12Last Post: 12-01-2023, 12:38 PM -
Used Axyz 6010 ATC for sale
By jimmy zenon in forum AXYZ RoutersReplies: 0Last Post: 17-05-2020, 06:26 PM -
AXYZ Pacer 900
By burnooot in forum AXYZ RoutersReplies: 1Last Post: 27-03-2017, 08:50 PM
